Hi Everyone,
I recently got a MK8 Fiesta ST, I've just got a trickle charger to keep the battery charged over lockdown. But I'm having some issues disconnecting the battery.
Firstly, the negative terminal is stuck on. The nut is loosened and the bolt is stripped at the end (it must have been done previously as I haven't touched it). Any advice getting it off? I would try to get a screwdriver in to wiggle it open but there's no room as the battery is quite far back and under the scuttle.
Secondly, I haven't seen a positive terminal like the one of the MK8 before (photo added), normally it's just a single bolt and nut you loosen and remove. Advice on removing that would be great, thanks.
Hopefully my next posts won't be about such basic maintenance!
