You raised the overall gearing by increasing the rolling radius. It would be wise to find out what difference this has made to the speedo and odometer accuracy. Your fuel consumption readouts will be wrong.
To have kept things correct you should have used 225/30/18?
Thanks for that John! I have found that the Speedo now reflects the GPS speed more accurately. Now have to keep in mind to do 30 through a speed camera rather than 32-33😅
For interest, here's Ford's recommended tyre pressures. I note that comparing 17" and 18" wheels the pressures are only changed slightly at the rear for normal load, and are the same for high load.
Take from that what you will as to how you might adjust if you change from a 205/40R18 to a 225/40R18
That's about where mine is set, I can't check as I don't have the car with me. You need to set the TPS for the pressures you drop them to to stop it going off - it's in the settings on the central dash display.
I've ordered some new 17" wheels and will fit the Ford recommended 205/45/17 probably PS5 or Goodyear F1 Asym 6 so it will be interesting to compare the feel of both once they arrive
Would 225/40 R18 reduce the chances of my better half scuffing the wheels over the standard 205 tyres ? Or would the extra tyre width offer no significant added protection to the rims ?
I put 225/40 R18 on the standard ST wheel for a while but they don't give a great deal more rim protection than the 205 tyre if you are wanting to stop them getting beat up by kerbs maybe try those nylon rim protector strips?
I've got these on mine now and my only answer is be careful
Have any of you fine folk fitted a set set of 225/40R18 to a MK8.5 on stock wheels with mudflaps? My concern is rubbing on the driver's side
Related Threads
Fiesta ST Forums
1.3M posts
41.3K members
Since 2004
A forum community dedicated to Ford Fiesta ST owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, engine swapping, troubleshooting, maintenance, and more!
