I understand what you're saying, but then that is the way Ford designed it - as do most manufacturers, as the legal tolerance on speedo accuracy says they can over read but never under read.225/40's are a better option as my GPS Speed on the dashcam proves the speed is low by approx 8% at 60.
But also, isn't the best option to try to match the oem circumference as closely as possible? Changing from standard could affect handling, unless you're doing it to address a handling issue that you've identified?
