Can't get a clean reading on dipstick?
4.3K views 7 replies 6 participants last post by  Ricostuart
Hi all,
I hope this isn't *me* being a dipstick, but...
Tried for the first time to check the oil on the ST tonight as I've got a long journey tomorrow.
However, every time I pull the dipstick out there's oil smeared the length of the long plastic end piece, not a clear line? Wiped it off, put it in, pulled it out, same result.
Car is cold and on the flat. Am I missing something?
#6 ·
You shouldn't check it hot straight after turning the ignition off because as mentioned you are waiting for the oil level to return to the sump and settle, but after you've wiped the dipstick clean and re-dipped you should get a positive reading even if a little residual has covered the rest of the rod.
#7 ·
Omg, how many mechanics do you see wait half an hour before checking the oil level after a service?? None. You just wait a minute or two then dip it, that being said the st180 is very hard to get a reliable reading I too find it smeared all the way up the dipstick, even after long periods of time not running, and the end is the wrong colour, when the oils clean you can't see the level at all.
