Hi, i been looking at carbon fibre vinyl online to do my wing mirrors, and know how easy this is or if there is a guide around somewhere? do i need specific vinyl?
Get the 3M stuff, its very flexible when heated and allows air / air bubbles to escape very easily when applying.
Heres a rough guide, any problems just ask.
Items needed
• De-greaser
• Stanley Blade
• Warm Soapy Water
• Air Dryer / Heat Gun
• Squeegee
• Time & Patience
Guide
• As you are doing your wing mirror caps, remove these.
• De-grease the area you want to apply the vinyl to.
• Get a spray bottle and fill this with warm soapy water, only use a little bit of fairy liquid.
• Cut the vinyl to size, you will need about 2" over hang for the vinyl as it needs to stick around the cap.
• Do one part at a time, i would start from the middle of the wing mirror cap and work my way outwards.
• Now to get it to stretch how you want it to, you will need a hair dryer or heat gun. In my opinion i will use the hair dryer and this is the right temperature. Gently hover the hair dryer over the vinyl (around 10-12cm), when you begin to feel the vinyl get soft this is when you need to stretch and stick down. To release air bubbles you will need a squeegee, gently use this over the area yiu have stuck to push bubbles out. Keep doing this until its complete.
• Make sure you add light squirts of soapy water as this will help realease the air bubbles.
Any problems just ask fella, hope this helps.
Terry
I found the biggest and most important factor for doing this is heat and PATIENCE!!!
i lost my rag many times and almost wasted a whole 500mm x 1000mm doing my wing mirror caps without a hair dryer lol also dont do it outside, its just too windy!
I find out things the hard way so you dont have to
haha!
