Hi, this is probably a lame question. Part of the bottom centre console has come adrift and is hanging off next to the seat fixings. No idea how this happened but I tried to push it back but it would not clip in. Has anyone had this problem, if so, how did you fix it back. Yes I know I can go to a ford dealer but it seems overkill for such a silly repair. Thanks if you have any ideas.
583313
Looks like the trim panel has not been put back correctly after changing the cabin/pollen filter. You will need to remove the screw cover further towards the front of this trim panel and then the torx screw behind. Remove the panel by sliding it forward and then refit by ensuring it is located firmly against the centre console at front and back and then sliding it rearwards to engage the plastic tabs. Then refit the screw and cover.
