As we all know it's all well and good doing a bit of spannering on your much beloved mk6 but without the correct info sometimes more damage can be done than good. as there isn't a specific Haynes manual for the mk6 st I thought I would set up a thread on the torque settings I find and use and keep them in one place.
Description.....Nm-lb/ft-lb/in
Air cleaner retaining bracket.....08 -- 71
Air cleaner resonator support bracket retaining bolts.....15 11 --
Battery cable to generator electrical connector.....15 11 --
Battery tray support bracket retaining bolts.....25 18 --
Camshaft sprocket retaining bolts.....72 53 --
Camshaft position (CMP) sensor retaining bolt.....06 -- 53
Engine front cover upper blanking plug.....10 -- 89
Engine front cover lower blanking plug.....12 09 --
Engine support insulator retaining bolts.....48 35 --
Engine harness bracket to valve cover retaining nut.....10 -- 89
Generator upper retaining bolt.....25 18 --
Hood latch lever retaining bolts.....15 11 --
Coolant expansion tank retaining nut.....08 -- 71
Coolant plug to cylinder block.....43 34 --
Coolant plugs (4) to cylinder head.....75 55 --
Power steering pump retaining bolt.....23 17 --
Power steering reservoir retaining bolts.....09 -- 80
Power steering pipe to the power steering.....65 48 --
Power steering bracket retaining nut.....15 11 --
PAS sply line to intake manifold retaining bolt.....11 08 --
PAS steering HP line retaining bracket retaining bolt......30 22 --
Power steering return line support bracket retaining nut.....15 11 --
Exhaust manifold bracket retaining bolts.....25 18 --
Exhaust manifold upper heat shield retaining bolts.....10 -- 89
Exhaust manifold lower heat shield retaining bolts.....10 -- 89
Exhaust manifold to the cylinder head retaining nuts.....55 41 --
Exhaust manifold studs to cylinder head.....17 13 --
Evaporative emission (EVAP) valve retaining bracket retaining nut and bolt.....10 -- 89
Cylinder block blanking plug.....20 15 --
Coolant pump pulley retaining bolts.....25 18 --
Coolant pump retaining bolts.....10 -- 89
Valve cover retaining bolts.....10 -- 89
Oil level indicator and oil level indicator tube upper retaining bolt 10 - 89
Oil level indicator and oil level indicator tube lower retaining bolt 10 - 89
Oil pressure switch 15 11 -
Oil pan retaining bolts 25 18 -
Oil drain plug 28 21 -
Oil cooler to oil filter adaptor retaining bolt 34 25 -
Crankshaft rear seal carrier retaining bolts 10 - 89
Flywheel retaining bolts a) - -
Oil filter adaptor retaining bolts 25 18 -
Positive crankcase ventilation housing retaining bolts 10 - 89
Knock sensor retaining bolt 20 15 -
Thermostat housing retaining bolts 10 - 89
Oil pump retaining bolts a) - -
Oil pump sprocket retaining bolt 25 18 -
Oil pump chain guide retaining bolts 10 - 89
Oil pump chain tensioner retaining bolt 10 - 89
Timing chain guide retaining bolts 10 - 89
Timing chain tensioner retaining bolts 10 - 89
Crankshaft position sensor retaining bolts 7 - 62
Accessory drive belt idler pulley retaining bolt 25 18 -
Intake manifold retaining bolts 18 13 -
Transaxle left-hand retaining bolts 44 32 -
Transaxle right-hand retaining bolts 44 32 -
Transaxle lower retaining bolts 40 30 -
Halfshaft center bearing carrier retaining bolts 48 35 -
Intermediate shaft bearing cap retaining nuts 25 18 -
Lower arm ball joint retaining bolt 48 35 -
Wiring harness retaining bracket nuts 20 15 -
Starter motor retaining bolts 35 26 -
Air conditioning (A/C) compressor retaining bolts 20 15 -
Engine rear mount retaining nut 90 66 -
Engine front mount studs to front cover 12 9 -
Engine front mount retaining bolts 48 35 -
Engine front mount retaining nuts 115 85 -
Strut and spring assembly top mount retaining nuts 25 18 -
Spark plugs.12 09 --
Ignition coil pack retaining bolts 6 53
Work in progress, will update with new settings and finish table as and when but you get the jist
