INDEX
- Sill end rust repair - here
- Change to Molten Orange seats - here
- Bonnets Vents by Nick Wiley: here
- Gear Box Oil Change: here
- 4yr/40k Miles Service: here
- Complete Brake Change: here
- Winter To Summer Wheel Swap: here
- Skirt Repair: here
- Mountune Rear Spring Isolator Upgrade: here
- Windscreen Replaced: here
- Biannual Service & Spark Plug Change: here
- Rear Spring Isolators Replaced Again: here
- Focus RS/ST170 Rear Caliper Refurb: here
- Busy Weekend: here
- Door Trims Wrap: here
- Pro Alloy Curved Intercooler Fitting: here
- MOT Emissions (2018, 2019, 2020, 2021): here
- Mountune RMM fails & visit to Collins Performance: here
- Vibra-Technics RH Engine Mount Fitting: here
- OZ Ultraleggeras & Michelin PS3's: here
- My lads PRO ALLOY Curved Intercooler fitting: here
- Ford o/s Engine Mount: here
- Team Dynamics 1.2 15x7J: here
- Poweflex Transmission Inserts & RS Exhaust Rubbers: here
- Sill end rust repair part 2: here
- Ford Fair 2021: here
- Cadwell Park visit: here
- Turbocharger Upgrade PERON S284 (Turbo Technics S280): here
- Finally fitted the OZ Ultraleggeras: here
- SPTA Micro Cordless Polisher: here
- 6 Months with PERON S284 Turbo Conversion, Soft99 Fusso Coat Wax: here
- 55k Service, Osram Night Breaker Bulbs: here
- CP RMM failure, Front Suspension Refresh, PowerFlex Engine Mount Insert: here
- 2nd Gearbox Oil Change: here
- PERON S284 12 Month Health Check, Air Filter Clean & VUDU Catch Can Fitment: here
- Front Grill Mod & Front Bumper Fitment Issue: here
- 13th Service & Mountune Radiator: here
- Mountune Radiator, 82C thermostat, Hoses & A/C delete at H-Sport Performance: here
- DEPSTECH DS450 Bore Scope images of Cylinders and Valves: here
Parts & Torque Settings:
Engine Oil:
Millers XF Premium LSPI 5w30
Castrol Magnatec Professional A5 5w30 (Ford Spec: WSS-M2C913-D & C)
Gearbox Oil: Castrol Syntrans FE 75W (renamed to Transmax Manual FE 75W)
Coolant:
Motorcraft® Orange Antifreeze/Coolant Prediluted / VC-3DIL-B (WSS-M97B44-D or WSS-M97B44-D2)
Genuine Ford Super Plus Premium Longlife Antifreeze. 1L: 2361569, 5L: 2361571
Spark Plugs: 1685720
(Spark Plug Socket)
Oil Filter: 1883037
Pollen Filter: 1566997
Brakes (Genuine FORD not Motorcraft)
Front Disks: 1751584
Front Pads: 1860476
Rear Disks: 1780880
Rear Pads: 1810990 (Performance) 5382847 (Comfort)
Front Slider Pins (1pk): Frentech-uk S7035-2 (S7035BZ-2)
Rear Slider Pins (2pk): Frentech-uk S7001CE (1pk S7001F-2)
Rear Disks for ST170 Conversion: 4411312
Rear Dust Shields for ST170 Conversion: LH 1141939, RH 1141940
Brake Bleeding
ForSCAN
Caliper nipple spanner Halfords Professional Flare 9mm x 11mm
Rear Caliper tubing 5mm, Front Caliper tubing 6mm (internal Diameter)
Miscellaneous:
Sump Plug Crush Washers: M14 x 20 x 1.5
Wheel Stud: 47mm M12x1.5
TPMS Metal Valve: 1936088
TPMS Rubber Valve: 2036832
Cat to Turbo Bolts x3: Finis# 5120109 (M8 x 29mm)
Cat to RMM Bracket x2 Nuts M8 x 1.25
Radiator Expansion Tank Cap: 1301104
82C Ford Thermostat: 2184696
Dash Air Vent (for boost gauge): 1781737
Right Hand Engine Mount (Ford): 5265556
Yuasa 71Ah 650A (278mm x 175 x 175)
RS MK2 Exhaust Hanger Rubber: 1688752
Halfords Number Plate Sticky Pads: HFX221
Eibach:
Pro-Kit Springs: E10-35-020-02-22
Spacers System 4: 15mm: S90-4-15-007
Spacers System 4: 20mm: S90-4-20-010
Fords Anti-Squeak Isolators: 1531725
Torque Settings:
Oil drain plug 28Nm
Gearbox plugs 40Nm
Spark Plugs 15Nm (Gap 0.028" or 0.7mm, Stage 3: 0.024" or 0.6mm)
Brake Caliper Slider Bolts 26Nm
Brake Caliper Mounting Bolts 70Nm
Brake Fluid Pipe Unions 18Nm
Brake Hose Banjo Union 26Nm
Engine Mount (Top Right) 3 x Nuts (engine side) 80Nm
Engine Mount (Top Right) 3 x bolts (chassis side) 48Nm
Rear Axle Bolts up to chassis (x3) 125Nm
Rear Axle Bush Through Bolt & Nut - 80Nm then tighten further 120degrees
