21 - 40 of 185 Posts
Another vote for the DV+. Great mod for any remapped car. I'll leave it at that as I agree with everything Micky says.
Cheers Kev.
Yes,I lubbed mine with engine oil. It's been fitted since 2018 and it works fine to this day, never relubbed it.
My understanding is that it's meant to self lubricate from the oil vapour in the system. I would have thought something like a catch can would remove much of the oil vapour in turn causing it to dry out. That's if I understand it correctly.
I would also say, if you get 20k-30k miles out of it, even if it does dry, they're so cheap to replace anyway... Could just buy a new one ha!
All good info, thanks Alex.
@Darran Personally I have heard so many people giving it the old "it does nothing", "its a waste of money", "it doesn't give you any more power" etc etc etc. but in my humble opinion it gave big improvements on re-application of throttle power. after installation the biggest change came on those sweeping bends or hesitant overtaking moves, the times where you have throttled up then release the throttle momentarily before re-applying. Prior to fit it seemed to feel like you had to re-build the boost pressure back up to get the power back on but after fitment the car just seemed to be alive for a few more seconds after throttle release and It felt like the car was already on full boost immediately the throttle was applied.
I totally agree it is NOT a mod that will suddenly give you more BHP but (IMO) it does decrease the rate at which the boost is lost therefore allowing you to keep up a faster better flow through the country lanes and during multi car overtakes (I am certain some will simply dismiss this as a placebo effect caused by my action of fitting a new device and wanting to see an improvement, but I can only say what I felt from the drivers seat)
As for lubing.. Mine went a 30,000 miles untouched (I do 12k+ per year) and was absolutely fine with no damage (at time of removal though I did get a nick in mine dropping the piston on the driveway :blush: so be careful if you do disassemble it to re-lube!! :lol: ). I re-lubed it (as I did at install) with clean engine oil as I thought harder greases/oils such as my trusty PX7 might impair its movement in the colder months. In all honesty though there was absolutely no reason to have done anything with it as it was moving perfectly upon removal as I only wanton to the system to confirm the servicability of the O-ring seal that some of the older ones had issues with... otherwise I would have probably done another 30K miles before I even thought to look at it.
The only issue I have heard mentioned regarding needing re-lubing that know of is if you have a catch-can fitted as this removes the natural oil vapour in the line therefore possibly??? resulting in the valve sticking.....
Hope that helps, i've tried to be as succinct as possibly but it's such a difficult thing to properly describe, below is a link to another thread with pic of mine after 30K untouched... (oh and my car always was MP215 and MR230 (2019) as some have mentioned it does not give any discernible changes to standard mapped cars)
https://www.fiestastoc.com/forums/topic/313573-gfb-dv/page-2?hl=dv
Thank you Micky for detailed reply, exactly what I wanted to hear lol, especially the bit about throttle response, on rare occasions I can feel the stock DV has vented all the pressure and there's a very slight delay when going back on throttle, must admit I've only felt it a few times but in those occasions I'm sure a GFB DV+ would have helped.
This morning I was just about to order one when I phoned Collins Performance about upgrading from CP2 to CP2-E but the guy I spoke to said their maps are not compatible with the GFB DV+, I mentioned I knew quite a few people running CP2 with GFB DV+ and were very happy, I went on to mention I knew a while ago GFB had issues with the o-ring and some units drying out but the guy from Collins said again GFB DV+ isn't compatible with their maps and it will fail in time, something to do with the spring.
So I'm not sure what to do now, keep with CP2 and get a GFB DV+ and upgrade my MT intake to ITG, I'm sure I'd gain a bit of performance on the bum dyno or what I was going to spend on CP2-E and CP actuator I could change tuner and go 2R, or stop scratching an itch go VT330R or S280 lol.
I'll ponder some more and in meantime get the intercooler and boost pipe kit fitted.
Guys, thanks for the input, much appreciated :nice:
This morning I was just about to order one when I phoned Collins Performance about upgrading from CP2 to CP2-E but they guy I spoke to said their maps are not compatible with the GFB DV+, I mentioned I knew quite a few people running CP2 with GFB DV+ and were very happy, I went on to mention I knew a while ago GFB had issues with the o-ring and some units drying out but the guy from Collins said again GFB DV+ isn't compatible with their maps and it will fail in time, something to do with the spring.
Never heard of that before. I've definitely seen plenty of people online running the two together.
"Race Red Owner"
It confuses me that unless they are saying go with another component such as their own recommended make to which they get dibs on or a different type i.e. blowoff valve.... How can they say an uprated product that uses the same signals and reacts at the same times as the OEM..... is not compatible???? Are they also therefore saying the factory item is not compatible?? or do they rely on their maps that the factory fitted valve will slip and release pressure under load and somehow build that in to the map????
If they offered a reason "it is not compatible because x,y,z" I could understand.... otherwise it almost sounds like either:
a. they asked for a discount to include it in the standard CPxx and GFB refused
or
b. They actually don't know if it will affect the map therefore prefer to err on the safe side and simply tell people don't fit it so they don't have to do the research themselves.....
That's very odd... First time I've ever heard that.
I do know that Collins stopped selling the GFB valves after the initial bad batches with the O Ring and never resumed selling them... But first time I ever heard about a tune not being compatible.
Also, I'm no expert, but I struggle to understand how a diverter valve wouldn't be compatible with map...
If it's any help, I am looking to get my custom mapped on a dyno.
I looked at CP2E myself, but from asking around, it seems a better use of money to get something tailored to the car... Especially since they can see the data.
I will go to Sabre Tuning in Castle Combe personally.
Discussion Starter · #26 ·
I remember reading somewhere Collins didn't recommend the DV+ but I can't remember where but yep I've seen/read many CP tuned ST180's with a DV+
or
It wasn't a sales pitch, they didn't recommend another valve, chat went something like: "nope, don't go with a GFB DV+, they're not compatible with our maps, it'll fail, we had a CP4 car in last week with a failed DV+", he didn't recommend any other recirc valve so I guess they use the oem part.
To be honest I'm not overly impressed with CP, their CP2 map is very good but whenever I've spoken to them it's seems it's their way or no way. On another subject I mentioned that I had their over-run option on my CP2 map, I mentioned since I've had a sport-cat fitted the pops are a little too much for what I want, I really like the low end burbles and crackles and would it be possible to buy another add-on with the high end pops toned down a bit, "nope sorry not possible, it's not as straight forward as that", by this point I'd had enough and said ok and good bye. Other tuners offer crackle maps, flamer maps, AK47 maps, WRC style add-ons etc but by all accounts according to CP it's not possible.
Anyway I'm waffling, thanks Micky for your comments.
Thanks Alex, if I go hybrid/big turbo I'd like to go custom tune.
Discussion Starter · #27 ·
Got around to fitting the PRO ALLOY Curved intercooler.
After reading both the Forge and Mountune front bumper removal guides the bumper was off within minutes
Hood Automotive tire Bumper Automotive exterior Automotive lighting
Tire Wheel Automotive tire Hood Motor vehicle
Replaced the stock intercooler hoses and baffled hard pipe with items from Mountunes Charge Pipe Upgrade kit
Bicycle part Automotive tire Bumper Material property Bicycle fork
Automotive tire Automotive exhaust Bumper Gas Pipe
The curved coolers locator pins fitted the bumper bar perfectly
Motor vehicle Automotive tire Hood Automotive design Asphalt
Automotive tire Gas Auto part Rim Engineering
Constant Tension Worm Drive Hose Clamps from HCL
Light Crankset Eyewear Automotive lighting Bicycle handlebar
Motor vehicle Grille Automotive tire Hood Automotive lighting
Once the cooler was plumbed in and when I attempted to refit the bumper I came across a small problem, the bumper wouldn't go back on, I had an idea what it was.
After plumbing in the cooler, when it came to refitting the plastic trim which goes along the bottom on the cooler I noticed I had to bend slightly the thin plastic trim bit to get the bolt in
Automotive tire Camera lens Reflex camera Camera Camera accessory
this trim was fouling the bumper, so I had to remove the trim, loosen the hose clamps and reposition the Alloy elbows and the silicon joiners each side until the trim pieces aligned correctly
Automotive tire Motor vehicle Tread Automotive design Bumper
after doing the above the bumper went back on fine.
Now that the sports-cat and intercooler are fitted I need to decide whether I'm going CP2-E or changing tuners and go 2R, or go hybrid/big turbo.
Anyone fancy taking me out in their VT330R or S280 car? :2): , don't mind travelling an hour or two from the East Mids, just don't want to spend 3k + and regret it afterwards.
Cheers.
"Race Red Owner"
Looking good @Darran ... but how many clamps do you have holding on that inlet to the intercooler!!!! :laughing:
As I mentioned earlier though regards the DV+, It uses the OEM solenoid, the OEM ECU signal to open it, OEM pipework.... In fact the only real changes are a high quality piston and improved springs..... How on gods green earth can it not be compatible?!? What next the mountune induction hose is not compatible needs to be OEM or the one they choose, The scorpion exhaust is not compatible needs to be the one they say...
I understand why mountune are precious as they make and/or sell all their own products and like with companies such as Apple it gives them the ability to know when they claim their component makes xxx power - it will as they know the exact spec of the components fitted within...
Have you watched the GFB video BTW it does go into the way it's made and how it works in great detail also sort of explaining why peeps like I say it is better throttle response....
Once the cooler was plumbed in and when I attempted to refit the bumper I came across a small problem, the bumper wouldnt go back on, I had an idea what it was.
Now that the sports-cat and intercooler are fitted I need to decide whether Im going CP2-E or changing tuners and go 2R, or go hybrid/big turbo.
Anyone fancy taking me out in their VT330R or S280 car? :2): , dont mind travelling an hour or two from the East Mids, just dont want to spend 3k + and regret it afterwards.
Cheers.
I needed one of those flexi bendy socket things. What are they actually called?
Looks like that would have made my life so much easier. Other than those wing bolts, bumper is easy to remove.
Looks good though, glad you're happy with the intercooler. I was very impressed with the quality/finish and that it fitted to all standard mounting points.
"Race Red Owner"
Do you mean a standard 1/4" Flexi extension? for example:
https://www.amazon.co.uk/Flexible-Internal-Hexagon-Support-Extension/dp/B074QTK3LK/ref=asc_df_B074QTK3LK/?tag=googshopuk-21&linkCode=df0&hvadid=344130989025&hvpos=&hvnetw=g&hvrand=856577316734435305&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046212&hvtargid=pla-698961962353&psc=1
or:
https://www.amazon.co.uk/Mixed-Flexible-Socket-Extesion-Adapter/dp/B0751K5VCX/ref=asc_df_B0751K5VCX/?tag=googshopuk-21&linkCode=df0&hvadid=344153295811&hvpos=&hvnetw=g&hvrand=8854563103228495094&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046212&hvtargid=pla-672833648542&psc=1
for all 3 1/4", 3/8", 1/2" (can't guarantee quality though!)
Though a good quality 1/4" or 3/8" UJ attached to a 12" extension can also do jobs like these but also give a higher torque load when required...
https://www.amazon.co.uk/Proxxon-23709-Universal-Joint-Sides/dp/B000S0LG46/ref=asc_df_B000S0LG46/?tag=googshopuk-21&linkCode=df0&hvadid=218081924305&hvpos=&hvnetw=g&hvrand=6316501179721211762&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046212&hvtargid=pla-423185998558&psc=1
:nice:
Discussion Starter · #31 ·
Definitely erred on the side of caution with the clamps :facepalm: , I removed a couple when the bottom trim was fouling the bumper but where possible I doubled up on the clamps, probably not needed with the stock turbo, but boost pipes blowing off with bigger turbo is quite common so thought I'd help stop that if I do progress further.
Yes I've seen the GFB YouTube video, all understood re. the benefits.
Yeah that little flexi 1/4" extension made the wings bolts easy, the one I've got is included in the Ford 46pc tool set I regular use, it's the smaller one which MickyD has linked, it's 1/4 drive about 6" long.
How are your vents after 2 years of being fitted? Ive made a booking with Nick but like you, Im really dubious about it - not so much from a water ingress point of view, more along the lines of it looking dreadful in 12 months time (peeling lacquer, fading, that sort of thing)
Discussion Starter · #34 ·
They're still spot on :nice:
Discussion Starter · #35 ·
Nothing much been happening with the car.
Car was booked in at Collins HQ for CP2-E and their actuator but cancelled due to lockdown 2.0.
Contacted Nick at AET about going VT330R, took ages to get a reply and when he did he gave me an email address to use, after two emails and three weeks still no reply, if their communication is this bad when wanting to give them best part of £3.5k I can only imagine how bad it would be if I had it fitted and had a problem. Been in contact with another company re. bigger turbo and live mapping, they've promised to contact me when hardware is in stock and they're in a position to fit, would be well after Xmas, I'm not holding my breath though.
Car suddenly got a vibration sound, turned out to be exhaust heat shield:
Car was in for MOT so bodged it with a Coke can, will replace heat shield fixings next summer:
Automotive lighting Drinkware Helmet Automotive tire Audio equipment
Car passed MOT with no advisories, since last pass cars been fitted with Milltek Sports Cat and CP2 overrun addon, so relieved it passed emissions.
Finally got around to giving car a well needed half decent maintenance wash and interior tidy up:
Car Steering part Vehicle Motor vehicle Automotive design
Wheel Tire Car Vehicle Motor vehicle
Tire Wheel Vehicle Car Photograph
Tire Wheel Car Vehicle Land vehicle
Probably one more contact wash this year when I change back to stock wheels then it'll be just contactless washes until weather starts to improve next year.
Discussion Starter · #38 ·
The Pro Alloy intercooler looks so good looking through the grill ha.
If you're not too far away, speak to these guys about options. I will go to them for a custom map instead of CP2E
https://m.facebook.com/sabretuning/
They're very well known in the Ford scene, especially with MK1 Focus RS. Great reputation
Cheers Alex, heard nothing but positive comments re. Sabre but unfortunately they're miles away from me, are you still thinking of going with Sabre?
That's some top notch bodging!
I didn't think I'd like it but the contrast the seats give looks great!
Thanks Kev, I still think the MO seats are very marmite with the blue but I like them, definitely look better when the car is clean which is very rare at this time of year.
Had a bit of a minor niggle with the car recently, started to feel very slight vibrations through steering wheel and pedals, first started to notice it not long after fitting the Pro Alloy cooler, so initially thought it could have been related to that, no extra vibrations were felt on idle, it was more after changing gear at approx. 3k as the engine reduced rpm but it was very minor though. More recent though under just moderate acceleration I did get wheel hop so something was definitely not right.
Quick look at the Mountune RMM showed it didn't look good:
Automotive tire Gas Wood Ingredient Auto part
This had been on the car coming up to 5 years and they have been known to fail, my lad had recently upgraded his RMM with a Collins mount, he didn't notice any extra nvh so decided to go with one of those.
From new my car had an annoying faint squeak which only appeared on dry days, fast forward 3 years and it turned out to be the RH top engine mount, squeak cured after a spray of silicon lub.
Last week I found myself close to CP HQ and after a quick call they fitted me in just before closing to check the engine mount:
Tire Wheel Car Vehicle Automotive tire
As I expected the RH engine mount is on it's way out, they didn't have a replacement but while there Ben removed the MT RMM and it was slightly out of shape so had their RMM fitted, vibration cured.
Will replace the dodgy engine mount with a vibra-technics FOR630M, hoping to fit that in next couple of weeks.
Had same problem with my Mountune RMM. Utter trash (as were their springs that rusted away in 8000 miles) took it off after a year as it made so much noise and chucked it in the bin. Replaced with a Collins one, and had no probs.
