21 - 26 of 26 Posts
Wifi, it connects and I gets a few readings but boost just doesn't seem to want to work, even when I try setting up new gauges etc
I have looked extensively on the ŵeb, and found example of this in action , but how do you enable Hud mode ? Ie invert the display?
Once you have it displaying the dials and readings you want (in menu option 'realtime information') select the settings menu (cog-wheel, bottom left when in portrait) and on the menu from which you start and stop logging you'll also have 'Toggle HUD mode'.
Select that and it shows all the displays as a perfect mirror-image.
You can see an image with this menu with this option visible in my first post.
cheers , it was a phone issue with a samsung, i did not realise it has two touch button at the bottom - one brought up the settings!
Somewhat off-topic but have you guys tried using Harry's Laptimer together with an OBD reader? I believe it has some of these features built in if I'm not mistaken?
@MarkCup
21 - 26 of 26 Posts
