101 - 120 of 134 Posts
Discussion Starter · #103 ·
Gave her a wash the other day as it was filthy.
Automotive parking light Tire Wheel Land vehicle Car
Wheel Tire Car Vehicle Vehicle registration plate
Got the ignition key fitted (Yes it looks shoddy haha)
Trunk Bumper Automotive lighting Hood Automotive design
Fitted the new door lock so I can lock the car.
Automotive lighting Window Hood Vehicle Motor vehicle
Done a 3 stage potting of the PPS.
Gas Bumper Auto part Telephone Metal
Hood Bumper Bicycle part Motor vehicle Automotive tire
Liquid Fluid Automotive tire Drinkware Drink
Fuel pump sub loom done.
Light Electrical wiring Cable Electronic engineering Auto part
Got the dash sub loom done today bar the DB9 can-bus connector.
Circuit component Electrical wiring Gas Electronic engineering Cable
Mocking up how I was going to add the 120o resistor for the keypad can-bus plug.
Circuit component Cable Electronic device Electronic component Wire
Got the DB9 connector on on the dash loom and tested it as well to check I got the CAN wiring right and the USB logging connector right as well.
Electrical wiring Fire sprinkler system Gas Electronic engineering Cable
Computer Personal computer Laptop Computer desk Table
Computer Personal computer Netbook Peripheral Output device
Also the pedal is finnished.
Automotive tire Bicycle handlebar Motor vehicle Electrical wiring Bicycle part
Got all the ecumaster hardware bolted in so I can now start the main PMU break out loom
Motor vehicle Hood Vehicle Automotive tire Automotive exterior
Discussion Starter · #106 ·
Been a long and busy week but got a lot done.
Got the PMU breakout loom made, I just have some tape on it while I test everything before braiding it. I use a bit of cardboard to help with the layout.
Hand tool Pliers Snips Diagonal pliers Table
Circuit component Pliers Wire stripper Round-nose pliers Electrical wiring
Table Circuit component Electronic engineering Desk Electrical wiring
Got the cartek installed, the main wire is just for testing right now, it will be done properly.
Electronic engineering Electrical wiring Computer hardware Electricity Trunk
The PMU and the start of the engine loom in place.
Electrical wiring Motor vehicle Gas Cable Auto part
Cable tied the sub looms in place.
Hood Automotive tire Motor vehicle Vehicle Steering wheel
Hood Light Product Vehicle Automotive tire
Fitted a new mains cable pass though.
Automotive tire Motor vehicle Automotive lighting Bicycle part Automotive exterior
And we have power and 2 working CAN networks.
Automotive tire Vehicle Motor vehicle Car Gauge
Audio equipment Vehicle Cockpit Electronic instrument Gas
I have now started on the engine loom, for now im just using a cut up stock loom and using deutsch connectors.
Motor vehicle Hood Automotive exterior Gas Steering wheel
Table Vision care Handwriting Eyewear Desk
Discussion Starter · #109 ·
Thank You all :)
Back to work full time now so progress will slow again but been at it after work tonight and got some more done.
Made the ignition, wideband & first of the 2 12 pin Deutsch connectors for the engine loom which has the crank/cam sensors, injectors and 12v wires. The 2nd 12 pin will have some sensors and the DBW.
I have made the IGN separate and I have ran 4 wires not 2 so its super easy when I want to swap over to run COP later on.
Circuit component Electrical wiring Table Electronic engineering Gas
Tableware Circuit component Pliers Cup Electrical wiring
Placed an order today for a single 10 bar pressure sensor & a LSU 4.9 wideband. I plan to run a lot of sensors later on but just oil pressure to begin with. Also ordered some AN3 line and fitting to mount it off the engine.
Discussion Starter · #110 ·
Got the 2nd 12 pin done for the sensors. Need to finnish the engine side of the sensor loom and add the PPS loom into the ecu then thats done.
Table Audio equipment Electrical wiring Gadget Desk
Table Circuit component Wood Electrical wiring Electronic engineering
Wood Electrical wiring Cable Table Pliers
Also looking at the steering wheel button mount.
Automotive tire Motor vehicle Bicycle part Rim Font
Discussion Starter · #112 ·
Got the sensor loom finished today, the LSU 4.9 wideband fitted as well as testing and setting up the sensors.
Table Electrical wiring Gas Cable Audio equipment
De-pinning one of the OE connectors
Automotive lighting Automotive tire Electrical wiring Bicycle handlebar Fender
Pliers Electrical wiring Wire stripper Round-nose pliers Cable
Plugged in loosely just to test.
Motor vehicle Car Vehicle Automotive design Auto part
Hood Vehicle Motor vehicle Automotive exterior Automotive design
I have the starter wire i need to run and the main batt cable to hook up, then its setting up the calibration and turning it over.
Ordered a cable blaster on monday from the US and got it today. Will allow me to access everything via wifi, no more usb cables in my laptop.
Just testing it.
Hood Automotive tire Automotive design Vehicle Motor vehicle
Computer Personal computer Laptop Output device Netbook
Also removed 2 of the brake feed lines to make them shorter and sort some leaks.
Spent the weekend at it. Doing lots of little jobs that take forever.
Got the wheel buttons all done
Wheel Automotive tire Motor vehicle Steering part Automotive design
Got the brake lines back in with need unions, battery is in with its proper cabling.
Motor vehicle Hood Automotive tire Automotive design Vehicle
Electrical wiring Electricity Gas Electrical supply Vehicle
Got the fire/power buttons wired in
Motor vehicle Hood Automotive design Electrical wiring Computer hardware
Mounted and wiring in the cable blaster
Hood Automotive tire Motor vehicle Vehicle Automotive design
Pedal back in.
Electrical wiring Engineering Gas Machine Electrical supply
Discussion Starter · #120 ·
@Driftingforlife what cable did you use for the steering wheel buttons? I think I may need some of it for my horn.
https://www.ebay.co.uk/itm/Coiled-Cable-6-Core-0-09mm-Screened-PU/172983845358?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I'm only using it to pull to ground mind, the wire is to thin for any thoughput.
Some nice progress there mate! If you don't mind me asking, where do you get your Shifter raiders from? After a set myself...
Cheers, they are home made i'm afraid.
