I had a binding issue with one of my heat shields and the part where it was splitting from 1 to 2 cables and clips to the underside, was exactly the issue your describing may be worth a look.
I will I can also hear a heat shield rattle so I suspect it’s that. I’ve got it working but it’s not perfect. I’ll take a look.I had a binding issue with one of my heat shields and the part where it was splitting from 1 to 2 cables and clips to the underside, was exactly the issue your describing may be worth a look.
Yer I saw that after I had the custom exhaust centre matching the miltek manifold and the mountune rear. 😅🫣Not sure if you’ve already seen this or not or got to the bottom of your exhaust issue but found this on EBay…
mountune MK6 Fiesta ST 150 Exhaust Manifold MP165 MR185 MR200 | eBay
As used on MP165 MR185 and MR200. mountune Exhaust Manifold for MK6 Fiesta ST 150 2.0.www.ebay.co.uk
There a specific nut for the speedline, sleeve nut with a taper.Fitted the speed lines after getting some alternative bolts for more thread engagement. Fitted a dream and the ride is good! Even on track day tyres View attachment 587765
Yep I got them, I tried the standard ones but I wasn’t happy with the engagement so bought theseThere a specific nut for the speedline, sleeve nut with a taper.
Interesting, as with the tyres I have on them, they weigh a lot more versus the zetec S ones I removed. I suspect the track based tyre is stiffer thus heavier, rather than the wheel.I was surprised how light they were without tyres.
