1 - 20 of 23 Posts
Vendor
Fiesta ST Fog Light LED
Diode Dynamics carries LED bulbs for replacement of your Fiesta ST's fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your fog lights a nice bright white that closely matches factory-equipped HID lighting! Just simple plug and play, replace the bulb and you are good to go! We also offer Luxeon LED Housings for a complete replacement of your Ford Fiesta ST factory fog light housings (See Install Video)
Diode Dynamics carries the brightest, highest-quality LED replacement bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: 850 lumens. Much brighter than factory. These are bright! USA Made!
*SLF is available in 3000K Yellow / 5700K Color Temperature Options*
Luxeon LED Replacement Housing: Powered by three genuine Luxeon T LED chips per side, the perfect 5000K white color provides a brilliant LED illumiunation, with a Trulux measured output of 600 lumens. (Please note: similar styles of lamp can be found online which claim much higher output, but these numbers are highly inflated. These lamps are the brightest on the market!)
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Luxeon LED Replacement Housing: Integrated projector lens distributes light in a wide, even pattern, compliant with DOT and ECE standards for use on-road. With a durable poly-carbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fiesta ST Fog Light LED
If you have any questions, please don't hesitate to post, PM, email [email protected][/email] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Ford-Fiesta-ST-Diode-Dynamics-Luxeon-Fog
Vendor
The Luxeon housings themselves retail for $160 /set
You'll receive a calculated shipping total prior to placing your order at our checkout page
Thanks!
Nick C.
Vendor
Discussion Starter · #11 ·
My apologies, I forgot to include that they do meet ECE regulations as well (as indicated by that marking)
These housings perform extremely well, and produce the ideal output pattern for the fog light location
Nick C.
If people want them to still be "fog" lights, then I would suggest the lower/equivalent output ratings. More light in fog = glare.
Vendor
Discussion Starter · #19 ·
http://www.youtube.com/watch?v=XFelKJrUZgU
Focus ST/Fiesta ST Diode Dynamics Fog LED Luxeon w/Projector Housing 2013-2014/2014-16 Installation
Installation video from authorized dealer: CJ Pony Parts
1 - 20 of 23 Posts
