well i have just purchased a full milltek system with a de-cat, fitted it early in the week. ive decided i dont like the raspy sound of which i presume comes from having a de-cat. i need help on deciding whether to get a sports cat (will it make it sound alot healthier) or can i keep the milltek mani and flexi with my standard cat?? anything would be much appreciated!!
hey bud
i am sure that all milteks make that noise even with a sport cat so if you dont like the sound you will have to change the cat back part of it
hope this helps
Let it ware in abit. I think you will find the noise will change abit. Sounds raspy in low revs but gets deeper at higher revs
thanks, yeah its starting to sound alot better now. another minor problem i have is that one of the hanging brackets rub on the exhaust casing causing it to rattle at times and squeek, is this common?
