21 - 24 of 24 Posts
Discussion Starter · #21 ·
Adjusted the meth injection settings today , as I’m now running 1.5bar of boost instead of 1.9 bar
got the injection starting at 8psi and max spray at 23 psi
topped up the tank too
I couldn’t be happier with the EP exhaust on the car which meads I’ve a milltek non res race looking for a new home now
Automotive tire Motor vehicle Bumper Gas Automotive exterior
Grey Camera accessory Camera lens Bumper Cameras & optics
Automotive tire Wood Fender Gas Motor vehicle
Liquid Fluid Drinkware Finger Cylinder
Motor vehicle Automotive lighting Automotive tire Automotive design Automotive exterior
Vehicle Gear shift Car Motor vehicle Automotive design
Discussion Starter · #22 ·
To get control over the boost pressure I had to remove my turbosmart plumb back mechanical valve and use a oem valve , the ecu can upen the valve to help control pressure… I didn’t know this
I wasn’t too happy about having the oem plastic valve on the car , so took advantage of the Xmas deals and picked up a turbosmart EM electronic recirc valve . Sounds amazing! Pleanty of flutter from the S280 at low boost and the ecu can still open the valve if needed
if anyone is thinking about the EM valves , get 1.Couldn’t be happier with it
Discussion Starter · #23 ·
The ebc floating disks are about spent now so going to place an order for some replacements this week
fitted a sight glass to the meth tank so I don’t have to keep opening the top to check it , it’s using quite a bit more with the new s280 turbo setup
also added a lufi gauge from spark plug Steve
Seems like a good bit of kit with the alarms set for high temps and shift lights
Automotive lighting Gas Audio equipment Circuit component Cameras & optics
Plant Speedometer Automotive lighting Motor vehicle Light
21 - 24 of 24 Posts
