1 - 11 of 11 Posts
Away to buy an induction kit for the fez, whats the difference between the 2 bar the name:p anyone have pics fitted and in the box?
do they give the same gains etc?
Cheers ozzy
I've got a k&n and have had no problems in the winter!
Now it's got warmer I'm looking for a heatshield...
If I could go back I would of brought a mountune cais..
The k&n does feed alot stronger in cold weather !!
the mountune cais is a semi sealed air box with a k&n inside.
it uses the cold air dam from the front panel that is typically used by the standard system.
it also has a cold air pipe which is most often mounted to the lower grill section.
i maybe wrong, but i think the mountune k&n is slightly larger than the 57i filter?
i can't quite remember.
the main benefit of the mountune air box is that it helps create a cooler environment for the filter to operate. and has a refined system for making sure the cold air is directed to it.
I think il just go for k and n as they seem to do the same thing:p and same gains bhp wise, i like the grunt off the k and n and have always went with them so it makes sense;) what do most people get gain wise with an induction kit? Ive heard as much as 10bhp?!
It's pretty much the same thing,Just one's open and one's Enclosed.
Same Induction Kit It's self Inside though.Personally I would say get the CAIS.
I have the k&n and I would say if you have the extra money
It's well worth it.. The mountune cais is a k&n but it has a semi
Enclosed heatshield around it and does help so much with keeping
Inlet temps down = (more power)
1 - 11 of 11 Posts
