241 - 260 of 260 Posts
Discussion Starter · #243 ·
Ford Power Live was a blast. Everything went well. Although the good company was the highlight rather than the event itself.
EnduraKA wasn't there this year and I fear that yet again, it's becoming just another show that's overrun with modified clone mk7s.
Maybe they're still to new for people to be doing something interesting and unique.
I'm sure there's one or two out there at uk show, somewhere, harnessing the power of Red-neck Science.
Anyway, here's a photo a friend took as we were getting ready to leave.
Car Automotive parking light Cloud Land vehicle Vehicle
Also, I made a new mount for the ecu.
Vehicle Motor vehicle Hood Automotive design Automotive air manifold
hi marv,
every time i see this car its got more holes drilled in it :ROFLMAO: :ROFLMAO: :ROFLMAO:
Discussion Starter · #245 · (Edited)
hi marv,
Gotta keep the crash bar nice and cool.
Also, I may or may not have just bought a 6 point cage. From a very reputable company at a better than vat free trade price.
Saving a whopping £360.
And unfortunately adding likely nigh on 80 odd kgs in weight.
Discussion Starter · #248 ·
Interior apart again today. Dash now comes out in 4 bolts and 1 nut. So really is no hassle to remove. Took the dash bar out, cut off what I don't need, gave it a lick of paint and back in it goes. The top bracket remains because it will be used to mount the loom and a secondary fuse board. Wiring is all over the show atm, will be tidying it up tomorrow.
Oh yeah. No more heater matrix, oem heater core remains until I get a race heater in.
Also spaced the steering position down 12mm (as I'm short).
Car Vehicle Motor vehicle Hood Automotive design
Car Hood Motor vehicle Vehicle Automotive design
If you're going more track focused, then while the dash is out, and before you fit your cage - you might want to dump the fuel pump inertia cut off switch. They are a pain with kerb strikes.
The good news is that it then makes for an easy place to wire in a fuel drain switch.
I'll be interested to see how you get on with the heater, I don't run one in mine - but I did retain the heated front screen. Driver cooling is a bigger problem in mine.
Discussion Starter · #250 ·
How is the fuel inertia switch wired? Just a live circuit on an inertia switch? Or is there any CAN wiring too?
Discussion Starter · #252 ·
Just the 12v.
You can just cut the two green wires from the base of the switch and splice them back together, to bypass it.
Lovely. Good to know. I don't have issues on kurbs tbh, stricter tracks like my local Brands Hatch don't like you crossing the kurbs on trackdays. To the point where I've been black flagged for it.
If I were out racing it'd be a very different scenario.
Discussion Starter · #254 · (Edited)
Hard wired a USB C lead to a dc to dc converter which has been fused off the new board for the tablet dash.
Got the dash back on and left the steering column plastics off. All that lovely wiring and paint hidden way didn't sit well with me.
Motor vehicle Automotive tire Hood Automotive lighting Automotive design
Plant Motor vehicle Vehicle Automotive tire Car
Got a meet tomorrow evening for a company called Hallscorts that build absolute monster classic ford's.
And Sunday I'm attending a cars and coffee local to me... which hopefully isn't full of financed tosh.
Discussion Starter · #255 ·
Some absolute classic weapons at the Hallscorts meet last night.
Only got a few photos before the sun went down.
As usual the typical F20 (Honda S2000 lump) with a stonking great turbo in a mk2 escort, is Hallscorts style. But all cars in these photos were running ford drivetrain.
Vehicle Car Automotive mirror Automotive lighting Mobile phone car mount
Hood Motor vehicle Automotive design Car Vehicle
Wheel Tire Car Vehicle Land vehicle
Tire Wheel Vehicle Automotive tire Automotive lighting
Car Wheel Tire Vehicle Automotive side marker light
Discussion Starter · #256 ·
Had a bit of spare time Friday afternoon to finally get the replacement bonet cut to suit aero catches and the Caterham inlet.
Cleaned it up and finished the underside in matt moondust silver to keep it looking oem.
For those of you that haven't seen what the cutouts usually look like on the underside of a bonet with aero catches... let's just say, it's less than desirable as you have to factor in an offset taper between upper and lower holes. Which cannot be measured and cut from the underside given the way the bonet structure curves. Unless you just cut out a gaping big square.
So I spent some time getting it as neat as I did and am very happy with the outcome.
Automotive parking light Car Vehicle Land vehicle Photograph
Tire Motor vehicle Automotive lighting Automotive tire Hood
Hi Marv,
Great job, ITs a shame the catches can't be got colour coded,
Discussion Starter · #259 ·
Hi Marv,
They can be sprayed, I just have no plans to do so.
That looks much the same as how I did mine, I used a Dremel and took my time. But I have seen a very neat job done with just a ~5inch hole saw.
I used a 29mm/ 44mm holesaw and a grinder to cut the excess.
It's the same size cutouts in the top and bottom skin.
That's right... The one I was describing had just hole sawed a big circle in the bottom skin, looked like a really neat but fast way to get it done.
I've got to attack mine again this week, as the 90mm Jenvey trumpets snag on the same bonnet bulge in the left hand corner.
