I'm probably being paranoid, but a couple of times when I've popped the bonnet with the engine still running I've noticed small bubbles (5mm max) dancing around in the coolant tank. Not many, 2 or 3 at a time around the small hoses that feed into the tank. It's not a stream of bubbles, more like a small pocket of air that's trapped in the flow of coolant.
No my immediate thought is bubbles in coolant is bad, but it's not like the whole lot is bubbling away.
On my last car the return feed was above the water line so would pour in disapating any bubbles I guess, where on the ST the return appears to push fluid back in from below do maybe like blowing a straw into a drink it's just the pressure doing its thing?!
Has anyone else noticed this happening at all?
