1 - 4 of 4 Posts
Hi people,
Just got given a free sub and amp. I need to buy a wiring kit, but was just wondering if it will connect to the standard ford 6006 headunit,
Has any1 has problems.
only problems you would get with attaching sub and amp to standard headunit would be lousy wiring. but by the time you buy all the adapters and wires for it and wire it all up, it would be so much easier just buying an aftermarket headunit
i did the same with my car
Hi people,
U can jus buy an rca coverter. U basically attach the speaker wires from the converter onto ur wires. The wires from the converter go into a box on oe side and the rca outputs come out the other side. It only costs bout 15 for one
Matt
Anyone know which wires are you off the back of the head unit that you connect the standard headunit? I presume the rears, but the wire colours or a photo would be helpful!
1 - 4 of 4 Posts
