1 - 4 of 4 Posts
Hi, there is this panel under the steering wheel:
Car Vehicle Gear shift Motor vehicle Steering wheel
I've an hard time to figure out how to remove it in order to better access the little air diretional flow motor to fix a broken plastic lever.
Thanks.
There are 2 10mm nuts one at each side holding it at the bottom, they are long studs so you will need a deep socket then there are 2 plastic tabs half way up each side of the panel. Remember to disconnect the battery as this is an airbag.
1 - 4 of 4 Posts
