will fitting decat without a map cause car to go into limp mode?
1 reading
3.4K views 11 replies 7 participants last post by  JackDavidson
as title says really, im sure ive seen it somewhere and cant find the link to it! if i fit the decat i know it will put the EML light on but will it make the car go into limp mode at all? thanks :)
#9 ·
Not so much the turbo 'wants' to boost more, it's that it can boost more. It's the whole "back pressure" topic.
On an N/A engine, you want a certain amount of back pressure in the system to keep things running properly... However, on a turbo, there are 2 parts where back pressure builds up... 1 between manifold and turbo and then after the turbo.
A turbo works best when the pressure builds up between the mani and the turbo, to spool it up...but then you want as little pressure as possible afterwards so that the turbo isn't being 'held back'.
Still, most sports cats give more than enough flow to give this benefit and keep things legal.
#10 ·
Just going off what Collins Performance said ;)
But that's a good description mate.
