1 - 4 of 4 Posts
yeah, thin flat bladed screwdriver in any side of the casing, quick flip and the case pops off.
As ST07 says use a small flat bladed screw driver,what i did was lower/tilt the mirror so it points to the ground ,that way you can look to see where the luggs are situated at the top
put your hand behind mirror so that when you push the casing does not pop off onto the floor and need to be re painted
1 - 4 of 4 Posts
