So after a fair bit of research I had Goodyear Eagle F1 Asymmetric 6 225/40R18 tyres fitted/balanced for £388. Had done 17800 miles on the OEM 205 tyres.
My initial assessment.
Upside: Saved lots of money - about £400. Personally I think the car looks better - the wheel/tyre combo fills the arches more, the tyres extend beyond the rim which looks much better than the "stretched" look of the OEM set up IMO. They should protect the wheels better (though bit late as the front rims are badly scuffed and due for replacement). Less road noise and slightly softer feel but that could be down to new thicker rubber. Less tendency to tramline or follow the camber. Less grabby / less torque steer on hard acceleration out of corners - not having to correct the steering as much - I have the LSD performance pack.
Downside: the speedo under reads by 2mph at an indicated 80mph and tyre doesn't look so skinny as sidewall is 8mm taller.
Overall an improvement I'd say - not sure why Ford used the 205/40R18 tyres which are stupidly expensive - they are actually the narrowest tyres you should fit to the OEM wheels.
FWIW I have no suspension modifications or mudflaps.
