U can program them urself! Heres how
To add a key. Think of your original keys as key 1 and key 2. Think of your new key as key 3. Each of the following steps MUST be completed within 5 seconds of the previous step.
1) Insert key 1 and turn to on for about 1-2 seconds. Switch off and remove the key.
2) Insert key 2 and turn to on for about 1-2 seconds. Switch off and remove the key.
3) Insert key 3 and turn to on and wait at least 5 second for the key to be memorised.
Repeat for any additional keys up to a maximum of 8 total.
Should you loose a key it is possible to erase it from the immobilisers memory by doing the following. Once again you still need 2 working keys.
2) Insert key 2 and turn to on for about 1-2 seconds. Switch off. Now turn back On for a further 1-2 seconds, off, and remove the key.
3) Insert key 1 and turn to on. The LED in the clock will flash rapidly for 5 seconds. Once the LED stops turn off and you're done.
All keys except for the 2 used during this procedure will be cleared.
What can go wrong?
If you have followed the above and are having no luck then it may be that you are too quick or too slow with the key swapping. It takes practice.
Remote locking
To teach a remote control the following procedure will need to be followed. It's quite simple and I'm sure with a little practice you will be able to do it with your eyes shut!!
For the ignition switch Accessory is (Pos I) and On is (Pos II)
1) Insert a key into the ignition and cycle from (Pos I) to (PosII) and back to (Pos I), 4 times within about 3 seconds. I know the Ford literature says 6 seconds but I have found this to be a more reliable method.
If you have successfully entered learning mode a chime should be heard. You now have about 30 seconds to complete the following step(s).
2) Now press any button on the remote control. If the learning was successful then a further chime will be heard. Repeat only this step for any additional remotes that you wish to teach to the vehicle.
3) Once you have taught all the remotes you can exit learning mode and try them by one of two methods. Either wait 30 seconds or cycle the ignition key to On then Off once.
It should be noted that if a new remote control is taught to the vehicle then remotes that were previously programmed will be erased. Handy if you've lost one or had it stolen. Teach all the required remotes at the same time.
