Fault Code Reader (enter your fault code to retrieve diagnosis)
4.5K views 5 replies 5 participants last post by  Chazzzzzer
#1 · (Edited by Moderator)
#4 ·
Had a engine management light come up today the code was u1900 does anyone know anything about this please.
Car was still running fine but think it needs a software upgrade as when I pop to the shops when I come out it don't want to start unless I give it a bit of throttle is a facelift 06 st could this be linked..
Rich
#5 ·
u1900 is a generic fault when there is a break down in communications with the CAN network ( controlled area network) in english and straight forward terms the ECU is not receiving a clear communication from anything from a sensor to a electrical fault.
usually you should get another code with a fault with this, so it may be worth taking to the garage and getting it onto a diagnostic kit to retrieve the code.
Considering the make and particular vehicle u1900 code has often been thrown up (with the same symptoms as you describe) as an ABS sensor fault.
#6 ·
Hi guys, iv been having problems with my traction control on my ST. Iv plugged the diagnostics into the car and it came up with the error code
- u2523 communication fault between the ABS ECU and the PCM.
It's really starting to annoy as I hate the light being on and that it just spins. Has anyone had this problem before any help would be much appreciated
