Foam pads in wheel arches - rust?
8.2K views 23 replies 13 participants last post by  KRaikkonenNo1
Sorry if this has been covered already, I have searched and couldn't find anything. Was washing the new car yesterday and noticed a foam pad inside the front wheel arches.
I am not sure why it is there really, and I reckon if left there, it'll hold moisture and be a potential spot for rust in the future. I used to have a mk5 golf, which are reknowned for this same issue, so much so that VW covered the cost of replacement front wings for a lot of people.
Any thoughts? I'm not sure if it's meant to be there, or if the dealership forgot to remove it during prep?
#10 ·
They fitted the same thing around the fuel filler on the mk1 ka and it was renowned for causing major rust and rot issues.
The ka had nothing like this fitted, the rust issue was down to the fact the vehicle had no rear wheel arch liners and poor sealing on panel joints. I have replaced many 1/4 panels on ka's due to this.
Ok, thanks for your reply Stonacre :) do we have any thoughts then if they are likely to be a potential problem in the future in terms of rust? Seems really silly having something in the wheel arch that's going to act as a sponge!
I don't think they hold water as they are a solid block of foam, no holes in it for water to get in.
#11 · (Edited by Moderator)
mk6's had those pads too, never noticed any rust in those area's. so hopefully mk7 will be ok
Just make sure to clean around the arch lips now and then as general mud and salt does cling in behind the lip. crap bulids up at the bottom of the wings too in behind the arch liner and inbetween the liner and sidekirt end cap, so worth remving them now and then and cleaning out
#18 ·
we dont call them acronyms any more.
theyre TLA's now.
I just died a bit inside when I read that. Partly at the very concept, and partly because I know what TLA actually stands for.
An acronym for a defined length of acronym. Wow. FML.
We have a whole department here at Dunton called NVH and they do this day in day out haha
Bet they are a barrel of laughs at the Xmas parties.
#19 ·
Talking of rust ... i no where they will start to go first ... in the middle of the little front quater window the rubber really holds the water ... if you wash your car and then dry it off there is always and good bit of water laying up against the bottom of the rubber ... i have started blasting the water out with an air compressor.
#20 ·
anyone that's worked aviation or oil and gas gets good at abbreviations, I've worked with doc packs where definitions took up 3 pages...
of course, if a SST is offline because the SCM in the SDU has a leak across the SCSSV DCV it's a bit of a handful saying it the long way...
i get enough funny looks off the neighbours when its cleaning day, im very reluctant to start blowdrying the damn thing, they may well think ive gone completely mad.
#21 ·
Funnily enough I noticed that on the weekend too while washing the car. Dried it all off with a bit of aqua wax, and that area was still dripping water down the door (or was it the wing?) hours later.
Suppose it depends how long we're going to keep the cars. I'm not sure whether I'll be keeping it longer than 3 years, but either way I'd still like to keep it in good condition even if it's only future owners that see the benefit. I'm looking into whether it's worth putting anything on the underneath of the car, such as waxoyl or dinitrol etc.
#22 ·
Yeah I've spent a lot of time potching with the new car already - cleaning, waxing, fitting LED headlight bulbs, trying to work out how the hell the stereo works. My missus and neighbours must think I'm mad. Gonna take all the wheels off soon to apply some sealant. I'm just trying to get some long term protection on the paint and wheels etc, and get the car to how I want it... But I do feel like a bit of an idiot on the drive pulling a brand new car apart and spending hours detailing it etc!
#23 ·
My neighbour is out playing with his car more than me so its not a problem ... is it wierd that i took the wheels off last week to clean inside them ?
