lambda sensor removal
573 views 9 replies 6 participants last post by  fez1607
does anybody out there no the spanner size needed to remove the lambda sensor
thanks!
#4 · (Edited by Moderator)
Do not do the above lol
The insides are made of ceramic, one bang with a hammer and you will crack the ceramic, which will cost you a new lambda
Get the exhaust off the car and either hold it in a vice or get someone to stand on it and use a 22mm spanner, may take a bit of effort but at least you will get it of in one piece. Also, do not use WD40 it will contaminate the lambda.
