As my ST/zetecS collection has expanded and I only have 2 legitimate parking spaces, decided to re purpose the bottom end of my rear garden
Just made the turn in from the side alley
Didn't make 24 hrs before the first "teething trouble" occured, was all set to wash the car and found the n/s electric window wouldn't wind up.
Fuse is ok and o/s works fine, so removed door panel to find
non standard motor.
I've got spare OEM motors, but was suprised that screws holding motor in appear to come out from the regulator side, where as the OEM motor screws go in.
If I remove the regulator, will an OEM motor mate with an aftermarket regulator ?
Is it possible to remove the motor ( without removing the regulator ) - access through the speaker appature ?
Any comments gratefully recieved ( guess what I'm upto tommorrow )
Oh yeah, I did get window up in the end, motor would move window up by about 10mm each time switch pressed if left 5 mins beween each operation.
2nd Issue. Leather door cards - the leather has seperated from the card.
I've replaced the leather section of the card on my zetec S ( as they were cloth covered ) so have no issue grinding off the tabs, removing the card and then building the tabs back up and plastic welding it back together.
My question: Will normal contact spray adhesive be ok to reglue the leather back to the card or is there a better option.
Thx
Al
