Well, I went back to work late last week which has eaten into the time I've got to spend on the car
Rightly or wrongly I decided to treat as much of the engine bay surface rust as I could find. I know its not a final fix as I need to get in and grind rust out, but it makes me feel a bit better not looking at brownness everywhere
I tried everything to go along with
@Marv_st advice to just pull the abs pump out of the way, but couldn't find anywhere I could manouvere it to that gave me clearance to get to attack the rust and get the sound deadening off, so again rightly or wrongly took it off.
I need to remove the bracket from the pump, then wrap it in cling film to stop any crap getting inside, I made sure I didn't rotate the pump so there is fluid inside
I need to get underneath later to unclip the fuel lines away from the bulkhead
Ford certainly didn't waste panther black paint when producing this car - If I was a "purist" I might look into what colour the "undercoat" was, but I'm not, I just want to stop the car rusting away, so its all going panther black
Last bit will be to take the servo off - I hate crawling around under dashboards, but Its got to be done.
Want to fit new sound deadening, I think there is zero chance of getting a decent second hand one, so a phone call to Ford is in order
Phoned them, part is obsolete no longer made. hmm, so I guess I need to be extra careful
Al
